Can 64-bit MATLAB be used with BCI2000?
trentb
When I try to run MatlabSignalProcessing through the BCI2000 Launcher interface, I receive the following errors:
11/2/2009 10:27:43 PM - MatlabFilter::Constructor: Could not load library libeng:
11/2/2009 10:27:43 PM - MatlabFilter::Constructor: Could not connect to Matlab engine. Please make sure that Matlab is available on your machine.
Through some debugging, I can confirm that libeng.dll is being found in "C:\Program Files\MATLAB\R2007a\bin\win64". I surmise that the problem is that libeng.dll is a 64-bit DLL instead of a 32-bit DLL. Is there any workaround to this problem without installing a 32-bit version of MATLAB?
-Trent
-Trent
trentb
Re: 64 bit
I have been unsuccessful in invoking the 64-bit MATLAB engine, and believe I know the reason. The 64-bit libraries provided by MATLAB are only for Microsoft Visual C++, not Borland C++. Borland is not supported by the 64-bit version of MATLAB. I will revert back to a 32-bit system.
-Trent
-Trent
trentb
v3.0 Operator Build Errors
Gerv,
Thanks for the advice. Version 3.0 builds without error until it gets to VisDisplayGraph.cpp of Operator. I get the following errors related to the limits class. I have tried to include limits provided by QT, but I still get errors. Any advice on resolving these errors?
1>VisDisplayGraph.cpp
1>C:\BCI2000_v3.0\src\shared\gui\SignalDisplay.h(332) : warning C4099: 'SignalDisplay::PaintInfo' : type name first seen using 'class' now seen using 'struct'
1> C:\BCI2000_v3.0\src\shared\gui\SignalDisplay.h(276) : see declaration of 'SignalDisplay::PaintInfo'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2065: 'numeric_limits' : undeclared identifier
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2275: 'size_t' : illegal use of this type as an expression
1> predefined C++ types (compiler internal)(19) : see declaration of 'size_t'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : warning C4003: not enough actual parameters for macro 'max'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2589: '(' : illegal token on right side of '::'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2059: syntax error : '::'
-Trent
-Trent
trentb
Re: v3.0 Operator Build Errors
Juergen,
Thanks for the change; however, I now get the following errors:
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : warning C4003: not enough actual parameters for macro 'max'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : error C2589: '(' : illegal token on right side of '::'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : error C2059: syntax error : '::'
I don't know if this will make any difference, but I am using Visual C++ 2008.
-Trent
-Trent
trentb
Fixed max error
Fixed it. The problem was that the compiler was getting "confused" between the macro max and the class member max defined in limits. I added the line
#define NOMINMAX
before every
#include <Windows.h>
and
#include "windows.h"
statement to disable the macro max. Surprisingly calls to the macros max and min do not return an error. I guess its able to find a definition of max and min somewhere without getting confused with the class member max in limits.
Trent
#define NOMINMAX
before every
and
Trent
trentb
Resolution
I installed 32-bit MATLAB on my Windows XP 64 system. I then ran BCI2000 (the version from 'trunk', not the soon-to-be-released 3.0) with the MATLAB filter without any problem.
-Trent
-Trent
