Gagandeep kaur
Post
by Gagandeep kaur » 09 Nov 2008, 12:47
hi grev,
i have just installed bci2000 on my machine and i need to know that how to get started... i have read the getting started page but i could not find that how can i use it offline... are there any stored signals available using which i can see that how it works from signal extraction to signal filtering ... till command signal generation
regards
gagan
TooT
Post
by TooT » 29 Apr 2011, 04:33
I have the same problem
I'm sure the user name and password I use are correct!
Have you solved the problem?? and how?!
