Environtment for Measuring Brainwave
reza
Post by reza » 03 Jul 2008, 04:15
dear Gary,
I want to ask about environment for measuring brainwave with EEG, since I am a new bee in this field. From your experiences, is there any conditional environment should be met to get better data? Would you please to explain it to me? Please advice. Thank you.
Note: I have a plan to trial P300 speller from BCI2000.
best regards,
reza darmakusuma
Environment
Post by gschalk » 03 Jul 2008, 13:06
Reza,
With environment, do you mean software or hardware? Please clarify. Thanks.
reza
environment
Post by reza » 04 Jul 2008, 05:32
dear Gary,
thank you for your reply. i mean about the environment condition, such as should i use dark room? is the test can be done at noisy environment? or others consideration. thank you. please advice.
regards,
reza darmakusuma
Environment
Post by gschalk » 04 Jul 2008, 13:24
Reza,
Ideally, you want to do EEG experiments in shielded rooms that do not have equipments that use a lot of power. Incandescent lights are also pretty bad.
I suggest consulting with somebody with EEG recording experience.
