A few random questions
Elizabeth
Post by Elizabeth » 20 Jan 2005, 17:27
I just have 4 random questions about the BCI setup. I looked through all the documentation, but needed some clarification on a few things:
1. Is there a way to have the EEG Source Signal window display more than 16 channels?
2. Does the BaselineHits matrix update on its own? Does it matter what starting values are put into the 2nd column (as long as there is a row for each target)?
3. When would SpatialFilteredChannels not be the same number as TransmitCh?
4. When is appropriate to change the SpatialFilteredKernal matrix to something other than a unity matrix?
I really appreciate anyone's help! :D
Elizabeth
Re: Random Questions
Post by gschalk » 21 Jan 2005, 17:13
Elizabeth,
Here are the answers to your questions:
Right-click on the EEG display will give you a number of options. You can always scroll using the cursor keys (EEG display has to be active).
This depends on whether certain adaptation variables in Statistics are turned on. You should have one row for each target. First column should be target number and second should be target probability (1/NumberTargets).
When you do not have a square matrix.
Whenever you would like to 're-reference' the signal. For example, in EEG people routinely use a 'Large Laplacian' filter. This essentially subtracts from a particular channel the average of some surroudning channels (to get rid of spatial noise). In this case, you might have five columns (for 5 TransmitCh) and only one row for one output SpatialFilteredChannel.
