bci2000_v1:: gUSBamp.exe (Release -> compilation error?)
mike
Post by mike » 07 Sep 2007, 09:08
I am not an expert using the C++ Borland 6.0 Builder. I am using Version 6.0 (Build 10.166). When I try to compile the gUSBamp.exe project:
Debug mode (by default): I have two warnings.
Release mode (I just click on the button): I have 7 warnings and 1 error.
[C++ Fatal Error] EDFFileWriterBase.cpp(169): F1001 Internal code generator error.
Am I doing something wrong with the compiler?
Thanks again for your help,
Javier
Borland Builder Problems ...
Post by gschalk » 07 Sep 2007, 12:43
Javier,
I am not sure what the problem is. Both v1 and v2 definitely compile fine using BCB 6, and that both using the IDE and using the "make clean && make all" command line.
You may want to reinstall Builder, perhaps on a different machine. As I mentioned, all projects should definitely compile.
