How can the BCI2000 synchronize with EEG Neurofax9100/9200?
compiler
Post by gschalk » 25 May 2010, 19:57
Elita,
It seems like you may be using a compiler that is not supported. BCI2000 v2.0 supports Borland C++ Builder, and V3.0 also supports VisualStudio and MinGW. Please check the build instructions on doc.bci2000.org.
It may be helpful to consult with experts in software engineering and electrical engineering.
Post by mellinger » 26 May 2010, 08:08
Elita,
add -lws2_32 to the linker options in your project. This should fix the linker errors.
--Juergen
