Matlab external lib and mat functions
Posted: 10 Mar 2011, 07:57
as promised in my precedent post, here is my new question. I would like to import data from a matfile into BCI2000. For this purpose I use the matlab extlib provided with BCI2000. I thus included in the CMakeList corresponding to my module the following line:
BCI2000_USE( "MATLAB" )
It helped me to get rid of compilation errors but I still have the following linkage errors:
Linking CXX executable C:\Coding\BCI2000\prog\EmoPlaySignalProcessing.exe
CMakeFiles\EmoPlaySignalProcessing.dir/objects.a(EmoPlayFilter.cpp.obj):EmoPlayFilter.cpp:(.text+0x4b): undefined reference to `matOpen'
CMakeFiles\EmoPlaySignalProcessing.dir/objects.a(EmoPlayFilter.cpp.obj):EmoPlayFilter.cpp:(.text+0x65): undefined reference to `matGetVariable'
CMakeFiles\EmoPlaySignalProcessing.dir/objects.a(EmoPlayFilter.cpp.obj):EmoPlayFilter.cpp:(.text+0x8d): undefined reference to `matClose'
collect2: ld returned 1 exit status
Are the lib present in the matlab directory only compiled for Borland ?
I am using mingw32 in association with CodeBlocks under windows 7 and with BCI2000 V3.0.
Also I do not know if this is related but I got that message when trying to use the matlab signal processing module:
MatlabFilter::Constructor: Could not load library libeng
Guillaume
------ Some things I did so far
Here are a few things that solved the situation but I would like your opinion on it and especially how to make it nicer.
1. change the matlab lib files that are in the extlib/matlab folder by those in my own matlab folder compiled with ld (the BCI2000 files where not recognized by mingw32),
2. rename the files "libxxx.lib" in the extlib/matlab folder to "xxx.lib" since for some reason all the lib annotations are removed by the cmake compilation (this one took me a long time to find),
3. change the cmake/extlib/Matlab.cmake file to include:
# Define the library directory
SET( LIBDIR_EXTLIB_MATLAB ${BCI2000_SRC_DIR}/extlib/matlab )
# Set the name of the library to link against within LIBDIR
SET( LIBS_EXTLIB_MATLAB mat.lib )
4. change the cmake/SetupExtLibDependencies.cmake to add at the proper position:
LINK_DIRECTORIES( ${LIBDIR_EXTLIB_MATLAB} )
SET( ${LIBRARIES}
${${LIBRARIES}}
${LIBS_EXTLIB_MATLAB}
that worked and I guess that some other needed lib can be added in the same way. I did not tried to recompile the whole BCI2000 to check if the "MatlabFilter::Constructor: Could not load library libeng" error disapears (if I add the libeng lib of course).
Please any comments are welcome or other / better solutions !
Guillaume
SET( ${LIBRARIES}
${${LIBRARIES}}
