covariance matrix estimation
Posted: 10 Feb 2011, 16:05
Hello everyone,
I ran into problems implementing a CSP filter when I realized that none of the covariance matrices estimated from my data were positive definite (i.e., alwyas one negative eigenvalue). I estimate the covariance R in one trial by
R = (X X')/ trace(X X')
and then average across trials (as recommended here)
As I am a newbie to EEG, I wonder about the most likely cause of this and how to address the problem.
- how many trials with how many data points do you normally need to estimate a covariance matrix? (can this be due to sparse data?)
- can this be due to insufficient artifact removal?
- is this a theoretical problem?
- a technical problem?
- is there a simple way to address this?
thanks a lot!
Marieke
[/url]
thanks a lot!
Marieke
[/url]
