Raw EEG plots
Posted: 27 Apr 2010, 02:33
by timo.veldt
I've created a few data files using BCI2000's:
- operator.exe
- gUSBamp.exe
- P300SignalProcessing.exe
And my own Application module, similar to StimulusPresentation.exe. However when I plot the averages of my targets (numbering 200) and non-targets (approximately 600) using matlab I get very weird scales.
My time axis runs from 0 up to 256, which is one second in samples. The voltage axis runs from -4000 up to 6000 across the different graphs. I was wondering what unit goes with this axis, since if it is nanovolts, things look considerably brighter than if it is anything else.
In matlab I've used load_bcidat(<filename>) and then used a script to use states.StimulusType and states.StimulusBegin to extract the data.
When plotting the entire signal (i.e. [signal, states, parameters] = load_bcidat(<filename>)) and then in the workspace window right-click signal and press "Plot all columns", I get approximately 9 minutes on the time axis and the voltage scale runs from -1.5*10^5 to 2*10^5.
So my question, what unit goes with the voltage scale???
Posted: 27 Apr 2010, 09:02
When using load_bcidat, specify the -calibrated option in order to obtain data calibrated into microvolts:
[signal, states, parameters] = load_bcidat( 'filename', '-calibrated' );
Otherwise, you get data in raw units, which depend on the SignalType, SourceChGain, and SourceChOffset parameters.
--Juergen
Posted: 27 Apr 2010, 09:59
by timo.veldt
Thanks for the suggestion, but I'm running into problems:
 [signal, states, parameters] = load_bcidat('testS001R03.dat', '-calibrated');
gives the following error
??? Error using ==> load_bcidat
File "-calibrated" does not exist.
Error in ==> getStimWaveForms at 4
How can use this?
Posted: 27 Apr 2010, 10:17
You must be using a very old version of load_bcidat. Please update to a current version of BCI2000.
To find out which mex file your Matlab installation is using, type
which load_bcidat
from the Matlab prompt.
To find out which version the load_bcidat mex file is, type
load_bcidat --version
--Juergen
Posted: 27 Apr 2010, 11:27
by timo.veldt
which load_bcidat
mario\data_io\load_bcidat.dll
This is indeed an older version, but I couldnt find the newer MEX file which is compatible to my system (XP, SP3, Matlab R2007b), so I used this one instead. Could you give me a direction to a newer file, or how I should build/create one?
Thank you again!
Posted: 27 Apr 2010, 11:39
The BCI2000 binary distribution comes with compiled versions of all the BCI2000 mex files. These should be compatible with your version of Matlab as well.
A list of recent BCI2000 binary distributions is available at
http://www.bci2000.org/wiki/index.php/BCI2000_Binaries
The latest BCI2000 binary distribution may always be downloaded from
--Juergen
