Unhandled Exception CoreModule.Run...
Posted: 03 Jun 2009, 11:02
Hello everyone,
I wrote a SourceFilter inheriting from GenericADC (it is basically a module to replay recorded BCI sessions). This module works as intended. But as i wanted to incorporate the FileWriter module it just refuses to work.
What i did was just inserting the required module in my makefile (fileio/ directory along with all the other required files). It compiles but when it starts up i get the following error:
If I dont include the DataIOFilter.cpp/.h in the compilation process it compiles, and starts up properly but no "Storage tab" is visible.
So how do I add these storage modules correctly to an existing source module?
Best,
Alex
03.06.2009 17:00:30 - BCI2000 started
03.06.2009 17:00:30 - CoreModule::Run: unhandled exception class std::bad_typeid (Attempted a typeid of NULL pointer!),
terminating SignalSource module.
Best,
Alex
