Sending information from an application to BCI2000
Posted: 19 Mar 2009, 14:09
by minamoheb
I am new to BCI2000 and I'd like to know whether there is a way to send information from an application to BCI2000.
And Is there a way to pause and continue the signal acquisition from an application?
Thank you
Controlling BCI2000 ...
Posted: 19 Mar 2009, 22:28
by gschalk
This is a very good question.
You can control BCI2000 from other applications in two ways:
1) On a run-by-run basis
2) Within a run
ad 1)
See http://www.bci2000.org/wiki/index.php/U ... _Scripting
for command line options. With these, you can load defined parameter files, set the configuration, and start the system.
ad 2)
Within a run, you can control BCI2000 by injecting values for particular states into the running system using the AppConnector protocol described on
Specifically to your question, you can set state "Running" to 0/1 to suspend/resume operation, or state "Recording" to 0/1 to stop/start recording.
resume
Posted: 30 Mar 2009, 12:12
by gschalk
Mina,
Actually, to correct myself: you can currently not resume operation using the Running state and the AppConnector.
