Configuration in nested matrix
Posted: 15 Feb 2009, 00:23
I have had problem setting nested matrix:
If I don´t set 5 columns in a matrix in TargetDefinitions (eg. setting 3 or 4) then System Log says:
"P3SpellerTask::Preflight: Application: Index out of range when accessing a parameter value, terminating module."
If I set in TextToSpell a character that exists in the first column (Display) of a matrix in TargetDefinitions but not exists in the second column (Enter) (eg. the configurations on the first row is: Display=1, Enter=<GOTO2>, Size=..., etc; and I set "1"), then System Log says:
"P3SpellerTask::Preflight: TextToSpell contains characters that are not available in menu 1."
I´m runninng BCI200: Source Revision: 2152, Suorce Date: 2008/10/02 18:35:43, Build Date: 2008/10/06 12:45:12.
If I'm doing something wrong please inform and if the problem is solved with new software versions delete the post.
Sincerely,
Ariel.
Sincerely,
Ariel.
