Parameter settings for neuroscan
Posted: 26 May 2008, 20:18
If anyone has used Neuroscan could you please let me know if there is a problem with the following parameter settings as the participants don't seem to be learning anything.
thanks.
We're using Neuroscan acquire 4.3.1 and 16 channels for the 1D 2target task.
Source tab
Neuroscan ADC
SourceCh 16
SampleBlockSize 20
Sampling rate 500
ServerAddress localhost: 3999
Signal Properties
ChannelNames F7 T7 P7 F3 C3 P3 Fpz Fz Cz Pz F4 C4 P4 F8 T8 P8
SourceChOffset 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
SourceChGain 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847 0.167847
Alignment
AlignChannels 0
SourceChTimeOffset
Online Processing
TransmitChList 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Filtering Tab
SpatialFilter
SpatialFilter common_average_16.prm loaded
ARFilter
WindowLength 0.5s
Detrend No
ModelOrder 16
OutputType Spectral Amplitude
FirstBinCenter 0Hz
LastBinCenter 30Hz
BinWidth 3Hz
EvaluationsPerBin 15
LinearClassifier
Classifier C3 9Hz 2 0.5
C4 9Hz 2 0.5
LPTFilter
LPTimeConstant 1s
Normalizer
NormalizerOffsets -1 32 (default)
NormalizerGains 1 0.5 (default)
Adaptation 0 2
BufferConditions
0 (Feedback)&&(TargetCode==1)
0 (Feedback)&&(TargetCode==2)
BufferLength 9s
Update Trigger (Feedback==0)
thanks very much
Emily
thanks.
Source tab
Neuroscan ADC
SourceCh 16
SampleBlockSize 20
Sampling rate 500
Signal Properties
Alignment
AlignChannels 0
SourceChTimeOffset
Online Processing
Filtering Tab
SpatialFilter
ARFilter
WindowLength 0.5s
Detrend No
ModelOrder 16
FirstBinCenter 0Hz
LastBinCenter 30Hz
BinWidth 3Hz
LinearClassifier
C4 9Hz 2 0.5
LPTFilter
LPTimeConstant 1s
Normalizer
Adaptation 0 2
BufferConditions
BufferLength 9s
thanks very much
Emily
