appconnector
Posted: 07 Oct 2007, 13:29
by nadoona
hi,
I want to read about developing applications and connecting them to BCI2000, but I can't find a detailed tutorial to help me in this subject. I've read the app_connection.pdf. do you have any detailed tutorial that talks about the appconnector?
thank you.
Posted: 08 Oct 2007, 09:53
Nadoona,
there are two demo applications that use the app connector:
src/AppConnectorApplications/ParallelSwitch
is a simple command line program that translates a BCI2000 state into hardware output
src/AppConnectorApplications/AppConnectorExample
is a GUI application that allows manipulation of BCI2000 state values (requires the qt framework which is available for download at http://trolltech.com/).
Posted: 08 Oct 2007, 13:32
by nadoona
thanks I saw those two applications, but I need to ask about two things. first, Do I need to open any application (like the screen.exe) in order to open the config window and work with app conector? because the operator window doesn't allow opening the configuration window without opening any application. second, if you can tell me about any tutorial that explains the app connector in more details rather than those two applications it would be great. thanks alot.
Posted: 08 Oct 2007, 14:46
by nadoona
to clarify more what I want. I want to make an application using C# and make it communicate with BCI2000 through AppConnector. can you tell me exactly what do I need to do because I can't find any information to help me in the documents. thanks a lot for ur help.
Posted: 09 Oct 2007, 08:56
Nadoona,
the AppConnector interface is part of the application modules.
To communicate over the AppConnector protocol, BCI2000 must be configured ("SetConfig") and running ("Run").
Further details are available in the AppConnector protocol description at
http://www.bci2000.org/downloads/doc/app_connection.pdf
which is also in the wiki at
http://www.bci2000.org/wiki/index.php/App_Connector
Posted: 09 Oct 2007, 18:52
by nadoona
hi,
thanks a lot for your reply. I Just want to make sure that I got it correct. so, I need to make an empty application module to run inside BCI2000 just to be able to use the AppConnector and connect to my external application. is this correct??
Nadoona
Posted: 10 Oct 2007, 08:24
Nadoona,
if you are going to use the AppConnector, then your application module needs to contain ConnectorInput and ConnectorOutput filter as a minimum configuration.
--Juergen
Posted: 06 Mar 2008, 09:10
by gsudre
From reading the documentation, I think the Appconnector can only be used to write to and read from the Application core module. Is that right? If so, is there any way to write to the core chain as an input to the Signal Processing core module? In other words, it would replace the source core module with an external program. Or is a source module the only way to write to the signal processing module?
Gus
AppConnector ...
Posted: 07 Mar 2008, 15:25
by gschalk
Gus,
The AppConnector protocol technically receives/sends data before/after the Application modules, respectively. However, please note that BCI2000 states are communicated through the system, so they will be available to all modules.
This can be used in many ways, but is best suited to send/receive 'passive' information, e.g., position of a joystick/mouse/eye tracker, etc. Please note that you can use the ExpressionFilter to combine these states (e.g., joystick position) with output produced by the classifier (so that you could control the output application using a combination of brain signals and external inputs, and that without any programming!). If you want to acquire raw data that are to be processed substantially (features extracted/classified, etc.), conceptually the cleanest way is to acquire them in the Source module.
