Mario visual tool question
Posted: 21 Aug 2007, 18:32
Dr. Schalk,
We were attempting to follow the steps that you provided Dr. Nam regarding the Screen.exe application today. The parameter configurations seemed to work very well, and we were clearly able to identify artifacts such as jaw clenching and eye blinking.
After a trial of Screen.exe, we were attempting to use Mario v1.5 in order to identify "strong" channels. However, we were unable to use Mario because of the following error: "This application has failed to start because mclmcrrt76.dll was not found. Re-installing the application may fix this problem."
I'm not really sure how to "re-install" this application. Furthermore, when we googled that particular dll file, we found that it was associated with Matlab?!?! Anyways, what are your thoughts? Would it be possible for you to send us that dll file to see if that would remedy the problem?
Thank you for your reply
