Problem with MatlabSignalProcessing
Posted: 08 Jun 2021, 10:05
by yunii
I am using the MatlabSignalProcessing module.
I get the following error message after a few seconds:
2021-06-08T21:54:30 - BCI2000 Started.
2021-06-08T21:54:30 - SignalSource: Waiting for configuration ...
2021-06-08T21:54:30 - SignalProcessing:
Waiting for Matlab to start up ...
2021-06-08T21:54:30 - SignalProcessing error, MatlabFilter::Publish:
Could not start Matlab: The system cannot find the file specified. (0x00000002).
Could not connect to Matlab.
2021-06-08T21:54:30 - SignalProcessing error:
Lost connection to SignalProcessing.
2021-06-08T21:54:31 - Application: Waiting for configuration ...
I have tried to started up the full path to the Matlab executable from the command line, but failed. It shows that 'MatlabSignalProcessing: Could not connect to operator module.'
Hopefully, some of you could point me into the right direction to solve this problem.
Thanks!
Re: Problem with MatlabSignalProcessing
Posted: 14 Jun 2021, 12:00
you need to enter the path to the Matlab executable into the batch file you use to run Matlab signal processing, not run MatlabSignalProcessing from a separate cmd line.
Let me know whether this solves your problem.
