System Latency using AmpServer and E-Prime
Posted: 29 Mar 2020, 09:45
Hi there,
I currently have the following system running:
Amplifier: EGI NA300
Source Module: AmpServerPro ADC
Signal Processing Module: FieldTrip Buffer
Signal Processing: MATLAB
Stimulus Generation: E-Prime 2
So basically everything is communicating via TCP/IP except, the stimulus triggers are sent via UDP to the Operator module of BCI2000. My question now is, is there any smart way to measure the latency of the system? So how to align the trigger with the EEG signal.
Therefore I need to know the latency of the stimulus presentation and the UDP connection, right? The TCP/IP should have time-stamps, right?
Hope some can help me.
All the best,
Emanuel
All the best,
Emanuel
