LSL Support?
Posted: 08 May 2018, 15:15
Hello world. Today I was (briefly) very happy to have stumbled across this:
https://www.bci2000.org/mediawiki/index.php/Contributions:LSLSource
because I would like to use LSL with BCI2000. However, if I look at the svn HEAD:
http://bci2000.org/svn/trunk/src/contrib/SignalSource/
I also don't see it. And if I look inside a working copy obtained from the release version ( http://www.bci2000.org/svn/tags/releases/current ), again inside /src/contrib/SignalSource , I also don't see it. In fact there's no filename containing the "lsl" substring anywhere in the working copy. Does the LSLSource exist? Is it maintained separately from BCI2000? How can I get it? Or is it in the same directory, so to speak, as HalfLife 3?
UPDATE: I guess I shouldn't have expected it in http://www.bci2000.org/svn/tags/releases/current since I now see that that actually gets me r4230 (release 3.05), some 5 years old.... I got there from https://www.bci2000.org/mediawiki/index.php/Programming_Reference:BCI2000_Source_Code#Access but I guess that advice must be out of date. Is there a different, canonical way to get stable (and/or release-corresponding) source revisions now?
