Testing a setup; only with RandomNumber?
Posted: 17 Oct 2006, 09:09
Fellow BCI researchers,
The BCI setup works fine, great work! However some things remain unclear. Therefore I would like to 'probe' a certain setup with known signals. When I am developping my own modules I would also like to be able to test them in this way. To this end I now use the RandomNumber (RN) source module.
The RN module can however only output two sines of one single frequency (right?). Is there an extension of (or alternative for) this module which is able to output slightly more complex signals? (A less pressing matter is that I get a stepwise and non-linear increase in amplitude of the sine if i modulate it with the mouse. I am trying to adapt the code to make the increase in amplitude more linear and softer...)
In line with this question I am also trying to read out the adapted parameters after each trial to see how they are changed for different 'brain' signals (which are of course no brain signals but come from RN) and for different settings for Statistics. Is there a more elegant way to do this than by writing a line in a log file from the Statistics filter?
Thanks in advance,
Pieter Laurens
University of Groningen
Thanks in advance,
Pieter Laurens
