Problems with connecting gUSBamp and BCI2000
Posted: 07 Jan 2015, 05:00
by steffenzander
Hi all,
I have a Laptop with Windows 7 64bit, gUSBamp ver3.0 and the driver is also ver 3.0. After starting BCI2000 (Administrator mode and user and latest version of BCI2000) i try to connect using gUSBamp. After clicking on "launch" a new window opens and say: "waiting for configuration". Thats all. I also tried the solution obn the wiki with ver 3.0 to remove the dll, the same problem. If i use the signal generator instead of the gUSBamp it works. I tried to start the gRecorder and the amplifier works, so its connected correctly.
If i start the gUSBampsource.exe manually there comes a failure: "The application was unabtle to start correctly (0x0000007b). Click Ok to close the application."
Does anybody have the same problems with gUSBamp and BCI2000?
Thanks!
Steffen
Re: Problems with connecting gUSBamp and BCI2000
Posted: 07 Jan 2015, 11:44
by boulay
Did you build from source or download the pre-compiled binaries?
Are your gUSBAmpSource binaries 32-bit or 64-bit?
Do you have the 32-bit or 64-bit g.USB driver installed?
It's a bit of a pain to get the 64-bit BCI2000 binaries working. The pre-compiled ones are all 32-bit. The 32-bit binaries require the 32-bit driver. The 32-bit driver installation fails on Windows 64-bit. Though it fails, it still puts the dll somewhere (sorry I can't remember where), and simply copying and pasting that dll into the same directory as your 32-bit gUSBAmpSource.exe file will usually do the trick.
Posted: 08 Jan 2015, 03:57
by steffenzander
everything is 64bit except the BCI2000....i used the precompiled version. I also tried to cvompile the sources but there where too many failures.....must be some problems with my visual studio and with minGW i also had problems. Thanks, i will try to install the 32-bit driver and try to find the dll. ;)
Have a nice day!
