Can't Build VS2010 due to TinyLib/SockStream error
Posted: 08 Aug 2014, 14:31
I'm currently start working on my master thesis and I try to get BCI2000 working on a Win XP x32 or a Win 7 x32 Virtual Machine.
I've downloaded the latest revision from svn and downloaded Visual C++ Express 2010.
I used cmake 2.8 (tested it also with 3.0) to generate a vs2010 solution and it seemed to work well (using external qt 4.8.6 or qt downloaded 4.7.0 from bci2000 worked also).
When I try to build the operator module, then I get build errors while compiling the TinyLib.dll, because of some errors in the SockStream.cpp and MemoryBuffer.cpp.
Maybe there is an easy solution for this, but I'm not that familiar with C++ yet (I'm working on it).
Therefore I hope someone can help me to fix this problem.
thanks in advance,
Markus
------ Erstellen gestartet: Projekt: ZERO_CHECK, Konfiguration: Release Win32 ------
------ Erstellen gestartet: Projekt: LibTiny, Konfiguration: Release Win32 ------
sockstream.cpp
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(864): error C2780: 'const _Ty &std::max(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt
C:\Programme\Microsoft Visual Studio 10.0\VC\include\xutility(2086): Siehe Deklaration von 'std::max'
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(864): error C2782: "const _Ty &std::max(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig.
C:\Programme\Microsoft Visual Studio 10.0\VC\include\xutility(2078): Siehe Deklaration von 'std::max'
kann 'int' sein
oder "std::streamsize"
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(897): error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt
C:\Programme\Microsoft Visual Studio 10.0\VC\include\xutility(2101): Siehe Deklaration von 'std::min'
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(897): error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig.
C:\Programme\Microsoft Visual Studio 10.0\VC\include\xutility(2093): Siehe Deklaration von 'std::min'
kann 'int' sein
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(898): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'size_t', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(899): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'int', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(911): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'size_t', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(912): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'int', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(974): warning C4244: 'Initialisierung': Konvertierung von 'std::streamsize' in 'int', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\sockstream.cpp(983): warning C4244: 'Initialisierung': Konvertierung von 'std::streamsize' in 'int', möglicher Datenverlust
MemoryBuffer.cpp
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(82): error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(82): error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig.
kann 'std::streamsize' sein
oder "int"
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(90): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'size_t', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(101): warning C4244: 'Argument': Konvertierung von 'std::streamoff' in 'ptrdiff_t', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(116): error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(116): error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig.
oder "int"
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(119): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'size_t', möglicher Datenverlust
..\..\..\..\src\shared\utils\Lib\MemoryBuffer.cpp(128): warning C4244: 'Argument': Konvertierung von 'std::streamsize' in 'size_t', möglicher Datenverlust
Code wird generiert...
------ Erstellen gestartet: Projekt: OperatorLib, Konfiguration: Release Win32 ------
LINK : fatal error LNK1181: Eingabedatei "..\..\..\frameworks\LibTiny\Release\LibTiny.lib" kann nicht geöffnet werden.
------ Erstellen gestartet: Projekt: Operator, Konfiguration: Release Win32 ------
========== Erstellen: 1 erfolgreich, Fehler bei 3, 1 aktuell, 0 übersprungen ==========
I didn't change any source code, so I think it should work as it is described in the wiki.Fehler 1 error C2780: 'const _Ty &std::max(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt D:\BCI2000\dev\trunk\src\shared\utils\Lib\sockstream.cpp 864
Fehler 2 error C2782: "const _Ty &std::max(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig. D:\BCI2000\dev\trunk\src\shared\utils\Lib\sockstream.cpp 864
Fehler 3 error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt D:\BCI2000\dev\trunk\src\shared\utils\Lib\sockstream.cpp 897
Fehler 4 error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig. D:\BCI2000\dev\trunk\src\shared\utils\Lib\sockstream.cpp 897
Fehler 11 error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt D:\BCI2000\dev\trunk\src\shared\utils\Lib\MemoryBuffer.cpp 82
Fehler 12 error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig. D:\BCI2000\dev\trunk\src\shared\utils\Lib\MemoryBuffer.cpp 82
Fehler 15 error C2780: 'const _Ty &std::min(const _Ty &,const _Ty &,_Pr)': Erwartet 3 Argumente - 2 unterstützt D:\BCI2000\dev\trunk\src\shared\utils\Lib\MemoryBuffer.cpp 116
Fehler 16 error C2782: "const _Ty &std::min(const _Ty &,const _Ty &)": template-Parameter "_Ty" ist mehrdeutig. D:\BCI2000\dev\trunk\src\shared\utils\Lib\MemoryBuffer.cpp 116
Fehler 19 error LNK1181: Eingabedatei "..\..\..\frameworks\LibTiny\Release\LibTiny.lib" kann nicht geöffnet werden. D:\BCI2000\dev\trunk\vs2010_32_dynamic\CMakeFiles\core\Operator\OperatorLib\LINK
Fehler 20 error LNK1181: Eingabedatei "..\..\..\frameworks\LibTiny\Release\LibTiny.lib" kann nicht geöffnet werden. D:\BCI2000\dev\trunk\vs2010_32_dynamic\CMakeFiles\core\Operator\OperatorQt\LINK
thanks in advance,
Markus
