SWLDA parameter selection method
Posted: 12 Jun 2014, 07:35
Hi everyone
I am using SWLDA 'stepwisefit' MATLAB function for P300 datasets.
1- Can anyone tell me the method to select suitable values for the SWLDA input parameters i.e. alpha to enter/ alpha to remove ??? Should I need to check manually every time to select the best input values for alpha to enter/ alpha to remove ??
I hope you understand the question
Thanks alot in advance
