BCI BAsics
Posted: 15 Feb 2014, 20:16
I am sri. I just started to work with BCI2000. I used Signal Generator ,FFT Signal Processing and Dummy Application. I have set the sine frequency as 100Hz in Signal Generator(source module) and only 4 channels in transmitted channel list. When I run the application, its running fine but when I applied the low pass filter of 30Hz still I am able to see 100Hz frequency in the frequency domain. can you please clarify me why its happening?
ii)I have and emotiv research sdk headset . I have acquired a motor imagery dataset and would like to observe the frequencies (analyse) in certain channels. Since its an offline analysis, do I need to use offline analysis module of BCI2000 which is analyzing the signal in matlab. or is it possible to analyse in BCI2000 without using source module.
Sri.
Sri.
