BCI2000 Matlab classification
Posted: 07 Jan 2013, 08:24
by mkroesen
Hi at all
Is there any Matlab-related software to load newer BCI2000-files into it? Because I've to know how the classifier is working exactly and there aren't enough informations about the P300_classifier.exe to redo classification in Matlab.
Markus
Re: BCI2000 Matlab classification
Posted: 07 Jan 2013, 20:05
by boulay
Markus,
If you don't have the source code, then follow the instructions at the following link:
http://www.bci2000.org/wiki/index.php/P ... ource_Code
To load BCI2000 files into MATLAB, look in "BCI2000\tools\mex" for load_bcidat.m
Make sure to add the above folder to your Matlab path, then read the documentation for load_bcidat
You can find more information at the following link.
http://www.bci2000.org/wiki/index.php/U ... _MEX_Files
If all you want to do is figure out how P300Classifier works then take a look at its source code in
BCI2000\src\core\Tools\P300Classifier
If you are interested in P300 classification in general I suggest you read the following article:
http://www.ncbi.nlm.nih.gov/pubmed/23250668
-Chad
Posted: 09 Jan 2013, 05:54
by mkroesen
Thank you! Your third answer helped me a lot to solve the problem
