Irregular block duration with actiChamp BrainVsion
Posted: 15 Oct 2012, 12:10
Hi everyone!
I've a problem with BCI2000 and actiChamp amplifier.
The problem is very similar to this one:http://www.bci2000.org/phpbb/viewtopic.php?f=5&t=1278
I use the RDAClient as Source module and StimulusPresentation as application module.
I make some records with windows 7 and analyzing offline the SourceTime state i notice irregular time block acquisition (also Timing window show the problem during the acquisition).
In this way i suppose that some sample are missed (for example when the interval between one acquisition block and the other appears to be 70ms ) and some sample are duplicated (for example when the interval between one acquisition block ant the other appears to be 8ms)
If i use windowsXP the acquisition stops (DataIOFilter::EvaluateTiming: Roundtrip time consistently exceeds block duration).
Has anyone of you the same problem? any ideas for solving the problem?
