*.bat files and neuroscanclient
Posted: 10 Aug 2012, 17:26
Hello!
Recently i've downloded binaries for Neuroscan and tried to run bci2000 on windows 7 64 bit (as wiki says "it is possible to run these 32-bit executables on 64-bit Windows systems").
Results are rather ambiguous (for me).
It seems when bcilauncher is used, everything works as planned (i've tryed neuroscan signal source module together with dummysignal processing [or P3SignalProcessing] and stimulus presentation modules - no errors were reported, stimuli were presented, data files were written).
Situation changes when i try to run modified (in the original StimulusPresentation_SignalGenerator.bat NeuroscanClient was used instead of Signalgenerator and new parameter file [obtained by means of the neurogetparams Command Line Tool] instead of "../parms/examples/StimulusPresentation_SignalGenerator.prm") .bat-file.
It looks like the source module can't connect to the neuroscan acquire system (acquire 4.5 to be exact)
When operator module windows appears, its impossible to start application. If i press "set config" nothing happens for some time, then it becomes impossible to even press "set config" button
(what i get is displayed on the attached file), also no eror messages appears.
Log file is as follows:
2012-08-10T17:40:54 - BCI2000 Started
2012-08-10T17:40:54 - Started "NeuroscanClient"
2012-08-10T17:40:54 - Waiting for configuration ...
2012-08-10T17:40:54 - Started "P3SignalProcessing"
2012-08-10T17:40:54 - Started "StimulusPresentation"
2012-08-10T17:40:55 - Loaded parameter file "C:\bci\BCI2000\prog\../parms/500hz.prm"
2012-08-10T17:44:10 - Operator set configuration
Can anybody please help me ?
Thanks in advance,
Ivan
Thanks in advance,
Ivan
