Add SourceFilter to NeuroSky module
Posted: 22 Mar 2012, 05:55
by dcscion
Hey all,
i am trying to compile the SourceFilter module from the emotiv signal source module into the NeuroSky module. My environment is WinXP SP3 along with Microsoft Visual Studio Express 2008. I successfully compiled the whole BCI2000 project at first.
In order to compile the SourceFilter, I added the particular headers and cpp files from the emotiv module. In the cmake file I added the following two lines, as seen in the emotiv cmake file, but edited the path:
 25 INCLUDE_DIRECTORIES( ${BCI2000_SRC_DIR}/contrib/SignalSource/Neurosky/lib/include )
 26
 27 BCI2000_INCLUDE( "SOURCEFILTER" )
Is my approach correct or do I need a different one? I heard that it was simple to add a SourceFilter to a particular module in a Borland environment.
Best, Dirk
Re: Add SourceFilter to NeuroSky module
Posted: 22 Mar 2012, 08:12
your approach is correct, and should work. However, you don't need the INCLUDE_DIRECTORIES statement in line 25. In the Emotiv source module, that line makes sure that the Emotiv library header is found. For the Neurosky module, no such statement is required.
