Problem with the operator module
Posted: 31 Jan 2012, 19:06
I have a successful build for BCI2000 using VS2010, I even tried using it to acquire signals from the Neurosky Mindwave and it is working fine. When trying to rebuild the BCI2000 on another machine using the VS2008 compiler, I faced a problem. Please check the images below. After I successfully built the core modules, operator module, P3signalProcessing and P3speller modules, and the neurosky source module, I then run the batch file ... On pressing the Config button in the GUI i get the dialog which as shown has missing tabs and when I open the source tab i find it lacking alot of parameters and thus when I load the parameter file and press set config and I get the error attached in the system log image.
NOw, I followed the same steps as I did before when building using the VS2010, what could possibly be the problem?
The following image is what I get when running the VS2010 built version:
Waiting for a reply and thanks,
-- Dina.
-- Dina.
