Application takes to long to confirm new parameters
Posted: 16 Nov 2011, 13:18
I've been recently experiencing problems with BCI2000 ver 3.0.3
I'm using g.tec g.USBamp equipment, on a Windows XP SP3 PC, with the latest drivers for Nvidia FX 5500.
for a P300 speller application experiment
The issue is that when I hit the "Set Config" button it take a lot of time since the "Start" button gets activated
I'm pasting the output of the "system log" window, so you can get an idea
2011-11-16T18:31:20 - Warning: gUSBampADC::Preflight: g.USBamp driver version = 3.
2011-11-16T18:31:21 - SignalProcessing confirmed new parameters ...
2011-11-16T18:31:21 - SignalSource confirmed new parameters ...
2011-11-16T18:36:37 - Application confirmed new parameters ...
It takes more that 5 minutes for the system to be able to run...
During that time the cpu load is more than 50% and as soon as the application confirms new parameters it drops down to normal
Honestly I don't know what the issue might be, since i'm using the same hardware
PS: I've tried version 3.0.2, and it works without waiting that much
what could be the issue?
