Changing stimulus frequencies within one run
Posted: 07 Nov 2011, 16:43
Hi
I was just wondering if there is any way to change the frequencies that different stimuli occur for different runs with in the same experiment.
For example, say I want the stimuli to be copied in the order 1 2 3. If I set the frequencies to 8 8 8, each stimulus will occur 8 times in all 3 runs. Is there a way to change it so that in the first run 1 only appears say 2 times but for the other runs it appears 8 times?
Leandra
Leandra
