Pausing BCI2000 from Matlab using FieldTrip
Posted: 01 Nov 2011, 10:04
by UCTEEGLab
Hi
I would like to be able to pause BCI2000 while I am doing some processing in Matlab. For example, if I am running the StimulusPresentation task, I want the process to be paused after one sequence and the next sequence to begin when I tell it to from Matlab.
I have tried doing this using ft_write_event as follows:
event_suspend.type = 'Running';
event_suspend.value = 0;
event_suspend.offset = 0;
event_suspend.duration = 0;
ft_write_event(filename, event_suspend);
This does manage to suspend BCI2000 but I then get a message:
Application: Unexpected Param message.
so I can't change the Running state back to 1.
Also, this seems to suspend BCI2000 and then restart the task - is there any way to just pause it within the same task and then continue from that point instead of starting again?
Leandra
Re: Pausing BCI2000 from Matlab using FieldTrip
Posted: 01 Nov 2011, 12:08
Hi Leandra,
are you using a recent version of BCI2000? The "unexpected param message" when setting the "Running" state to 0 should have been fixed long ago.
In order to pause and continue BCI2000 from a state, you will need to modify the application module. In src/shared/modules/application/StimulusTask.cpp, you might change all lines that read
doProgress = true;
to
doProgress = State( "MyState");
Also, in the constructor of that class, add a state definition line:
BEGIN_STATE_DEFINITIONS
 "MyState 1 0 0 0",
END_STATE_DEFINITIONS
This way, you should be able to control BCI2000 by setting the "MyState" state.
Also, in order to interrupt recording to the data file, set the state "Recording" to 0.
Posted: 02 Nov 2011, 03:54
by UCTEEGLab
Thanks for the reply.
I'm using version 3.0.2, which is why I was surprised to see that message because I did read somewhere that it had been fixed.
Thanks for the suggestion about pausing BCI2000, I will give that a try.
Regards
Leandra
