Signal Acquisition Issues with ModularEEG
Posted: 02 Sep 2011, 10:44
Hi
I am trying to acquire data using ModularEEG boards but the signals I appear to be getting do not look normal. I have attached a screenshot which shows a lot of square peaks within the signal. The screenshot was taken with the electrodes connected to a subject performing no movement.
My setup is as follows:
- 3 modularEEG amplifier boards (6 channels)
- 1 modularEEG digital board
- Since there is no serial port on my laptop I am communicating via a serial to USB cable which is set up as COM port 2
When I connect the same setup to Brainbay instead of BCI2000, the signals appear normal - I have attached another screenshot showing this.
If anyone has had similar problems I would greatly appreciate some help.
Leandra
Leandra
