Trouble using mem() function in MATLAB
dyd1985
Post by dyd1985 » 13 Jun 2011, 16:55
I'm trying to use the mem() function in MATLAB with EEG signals imported using load_bcidat('..','-calibrated'), but the plots I get are very weird, the spectral power decreases exponentially. So in order to test the MEM function I'm trying to use some sinusoidal inputs plus white noise (because I read that MEM doesn't behave well with pure sines). Again the plots I'm getting don't make any sense... this time the spectral power increases exponentially. If I use the pwelch() I get the right spectra for my sines instead.
The parameters I'm passing the mem function are:
sampfreq = 512;
ModelOrder= 16;
FirstBinCenter= 0;
LastBinCenter= 30/(sampfreq);
BinWidth= 1/(sampfreq);
EvaluationsPerBin= 15;
settingtrend = 1;
As usual thanks for your help.
Alessandro
Re: Trouble using mem() function in MATLAB
Post by gschalk » 13 Jun 2011, 20:37
Allesandro,
I would have to check the documentation again, but I think
LastBinCenter should be 30, and not 30/(sampfreq);
Same for BinWidth.
dyd1985
Post by dyd1985 » 14 Jun 2011, 11:01
Hey Gerv,
as always thank you so much. I tested and you were right, LastBinCenter and BinWidth must be specified in Hz and not as normalized frequency.
Alessandro
