Hi All,
I am very new to BCI2000 , I am trying to stream data via Micromed EEG system to BCI. When I click on Micromed application in the prog folder , it throws an error "Micromed :Could not connect to operate Module" Does anyone the know the potential solution to the problem?
Thank you!
Rahul
Micromed: Could not connect to operate module
Re: Micromed: Could not connect to operate module
BCI2000 consists of a set of 4 modules that need to run in order to make up a working system.
To start up BCI2000, use a batch file from /batch, or use the BCI2000 Launcher from the /tools folder.
It is strongly recommended to read and follow the "Getting Started" tutorial document in the root folder of BCI2000.
Jürgen
Jürgen
Users browsing this forum: Bing [Bot] and 3 guests
