The error is BCI2000 link to neuroscan
lijing
Post by lijing » 08 Apr 2021, 22:47
When I use the latest version of BCI2000 to connect to scan4.5, BCI2000 has been stuck in the state of requesting connection. But when I use the 3.03 version of BCI2000, it can connect normally. Signal source module is NeuroscanClient, signal processing module is DummySignalProcessing, application module is FeedbackDemo.
Re: The error is BCI2000 link to neuroscan
Post by mellinger » 10 Apr 2021, 08:12
what do you mean by "latest version"? A download from the BCI2000 website, or did you compile from source?
--Juergen
lijing
Post by lijing » 11 Apr 2021, 06:29
I've tried both. One download from BCI2000 wensite is BCI2000 Binary, another one download from SVN for compling.
Post by mellinger » 12 Apr 2021, 12:32
Unfortunately, we don't have a Neuroscan amplifier nor the Scan4.3 software available to test.
We can do remote debugging, if you agree, using Google Remote Desktop. Let us know your location so we can pick a time that is convenient for both of us.
lijing
Post by lijing » 09 Aug 2021, 22:50
Sorry, it took so long to reply. I was anxious to carry out the experiment and used the old version of bci2000. I'm in China. You can choose a suitable time.
Post by mellinger » 10 Aug 2021, 12:51
I'm in Germany. 19:00 your time tomorrow will fit me well.
lijing
Post by lijing » 11 Aug 2021, 03:11
Is it 19:00, August 11, 2021 Beijing time?
About three hours later?
Post by mellinger » 11 Aug 2021, 05:09
Yes, that is what I suggested. But we may start now if it fits you.
lijing
Post by lijing » 11 Aug 2021, 05:28
Our Google Remote Desktop code is 1994 0502 7716.
What happened? Was the connection accidentally disconnected?
Post by mellinger » 11 Aug 2021, 06:33
I accidentally pressed the "back" button in my browser, sorry.
Post by mellinger » 11 Aug 2021, 06:57
On the Neuroscan site, I found a FAQ document (http://compumedicsneuroscan.com/wp-cont ... n-FAQs.pdf) that mentions Scan 4.5.1 hotfix 2 to be downloaded here:
https://www.dropbox.com/s/6kmhvrgd98qdv ... 2.exe?dl=0
Did you install Scan 4.5.1 hotfix 2? If not, does the problem persist after installing it?
Post by mellinger » 11 Aug 2021, 07:24
I added a parameter RequestExtendedInformation which is off by default. So the issue should be solved for you.
Thank you for reporting.
lijing
Post by lijing » 15 Aug 2021, 09:52
After installing scan 4.5.1 hotfix 2, the problem still exists.
After updating bci2000, the problem is solved.
Thank you for your help.
Post by mellinger » 16 Aug 2021, 05:40
Thanks for the information, and best regards,
Jürgen
