I can't start the MatlaSignalProcessing module normally.
zyanfu
Post by zyanfu » 01 Mar 2019, 02:36
Hi
When I start the MatlaSignalProcessing module, I get the following error.
"MatlabFilter::Constructor: Unhandled Win32 exception 0xc0000005: ACCESS_VIOLATION
Terminating SignalProcessing module."
As a newbie, I don't know the specific reason.
Re: I can't start the MatlaSignalProcessing module normally.
Post by mellinger » 05 Mar 2019, 11:17
in older versions of BCI2000, this occurs when your Matlab installation is not in the system path.
Also, if you have both a 32 and 64 bit version of Matlab installed, it may be that your system path mixes directories from the 32 and 64 bit versions of Matlab, respectively.
