bcı source code building error
ykutlu
Post by ykutlu » 28 Jan 2019, 16:03
when i was trying build bcı2000 source code zip file visual studio giving me LNK2001, LNK2019, MSB6006, MSB3073, LNK1120, LNK4098 error ı can't find what is wrong because ı made everything just like building page it is giving me error .It is not just that it is also giving me authentication error and when ı try update svn it telling me bcı2000 locked it is not update or download the files.
Re: bcı source code building error
Post by mellinger » 06 Feb 2019, 11:00
Maybe the instructions you followed are outdated.
Please follow these instructions:
https://www.bci2000.org/mediawiki/index ... ng_BCI2000
ykutlu
Post by ykutlu » 07 Feb 2019, 07:22
ı did every step but it is giving me error. When ı was building it is not compile with visual studio and giving me 29 error.
Post by mellinger » 07 Feb 2019, 10:53
Are you using VisualStudio 2015 or newer?
ykutlu
Post by ykutlu » 10 Feb 2019, 12:34
i am using visual studio 2017
Post by mellinger » 12 Feb 2019, 08:59
What kind of error does it give you?
ykutlu
Post by ykutlu » 12 Feb 2019, 09:25
It's giving me these error . I closed my defender and don't have antivirus program i looked for solution but it is not change anything if you give me some advise it would be helpful
Error LNK2019 Unresolved external symbol "void * __cdecl operator new [] (unsigned __int64)" (?? _ U @ YAPEAX_K @ Z), "public: void __cdecl Vector <wchar_t, 64> :: resize (unsigned __int64)" (? Resize BundleStub referenced in @? $ Vector @ _W $ 0EA @@@ QEAAX_K @ Z) C: \ BCI2000src \ build \ CMakeFiles \ buildutils \ AppBundler \ BundleStub \ Stub.obj 1
Error LNK2001 Unresolved external symbol "void * __cdecl operator new [] (unsigned __int64)" (?? _ U @ YAPEAX_K @ Z) BundleStub C: \ BCI2000src \ build \ CMakeFiles \ buildutils \ AppBundler \ BundleStub \ ZipFileSystem.obj 1
Error LNK2001 Unresolved external symbol "void * __cdecl operator new [] (unsigned __int64)" (?? _ U @ YAPEAX_K @ Z) BundleStub C: \ BCI2000src \ build \ CMakeFiles \ buildutils \ AppBundler \ BundleStub \ NtHookFs.obj 1
Error LNK2019 Unresolved external symbol "void __cdecl operator delete [] (void *)" (?? _V @ YAXPEAX @ Z), referenced in the "void __cdecl LoadMainExecutable (void)" (? LoadMainExecutable @@ YAXXZ) function BundleStub C: \ BCI2000src \ build \ cmakefiles \ buildutils \ appbund the \ bundlestub \ Stub.obj 1
Error LNK2001 Unresolved external symbol "void __cdecl operator delete [] (void *)" (?? _V @ YAXPEAX @ Z) BundleStub C: \ BCI2000src \ build \ CMakeFiles \ buildutils \ AppBundler \ BundleStub \ ZipFileSystem.obj 1
The bug excludes LNK1120 2 unresolved BundleStub C: \ BCI2000src \ build \ CMakeFiles \ buildutils \ AppBundler \ BundleStub \ Release \ BundleStub.exe 1
Error MSB6006 Exited with code 1 from "cmd.exe". VersionCheck C: \ Program Files (x86) \ Microsoft Visual Studio \ 2017 \ Community \ Common7 \ IDE \ VC \ VCTargets \ Microsoft.CppCommon.targets 209
Error MSB6006 Exited with code 9009 from "cmd.exe" AppBundler C: \ Program Files (x86) \ Microsoft Visual Studio \ 2017 \ Community \ Common7 \ IDE \ VC \ VCTargets \ Microsoft.CppCommon.targets 209
Warning LNK4098 defaultlib 'LIBCMT' conflicts with the use of other libraries; / NODEFAULTLIB: use the library BCI2000MediaPlayer C: \ BCI2000src \ build \ CMakeFiles \ core \ Tools \ BCI2000MediaPlayer \ LINK 1
Error MSB3073 "SetLocale
"C: \ Program Files (x86) \ cmake-3.8.2-win32-x86 \ bin \ cmake.exe" -E make_directory C: / BCI2000src / build / CMakeFiles / buildutils / AppBundler / Test
if% errorlevel% neq 0 goto: cmEnd
"C: \ Program Files (x86) \ cmake-3.8.2-win32-x86 \ bin \ cmake.exe" -E copy C: /BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe C : / BCI2000src / build / CMakeFiles / buildutils / AppBundler / Test || "C: / Program Files (x86) /cmake-3.8.2-win32-x86/bin/cmake.exe" -E remove C: /BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe && "C: / Program Files (x86) /cmake-3.8.2-win32-x86/bin/cmake.exe" -E touch_nocreate .notexist
: cmend
endlocal & call: cmErrorLevel% errorlevel% & goto: cmDone
: cmerrorlevel
exit / b% 1
CmdOK to
if% errorlevel% neq 0 goto: VCEnd
setLocale
Release \ BundleTest.exe --create 1048576 C: /BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/testdata.bin
.. \ Release \ AppBundler.exe C: / BCI2000src / build / buildutils / BundleTest C: /BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe C: / BCI2000src / build / CMakeFiles / buildutils / AppBundler the /Test/Testdata.bin=Test/Test.b
.. \ .. \ .. \ .. \ buildutils \ BundleTest --test 10000 - C: /current.app/test/test.bin
: cmend
: cmerrorlevel
exit / b% 1
CmdOK to
: Exits with the code 9009 from the "VCEnd" command. BundleTest C: \ Program Files (x86) \ Microsoft Visual Studio \ 2017 \ Community \ Common7 \ IDE \ VC \ VCTargets
Warning LNK4098 defaultlib 'libcmt.lib' conflicts with the use of other libraries; / NODEFAULTLIB: use the library P3Speller C: \ BCI2000src \ build \ CMakeFiles \ core \ Application \ P3Speller \ MSVCRT.lib (initializers.obj) 1
Warning LNK4098 defaultlib 'libcmt.lib' conflicts with the use of other libraries; / NODEFAULTLIB: use the library StimulusPresentation C: \ BCI2000src \ build \ CMakeFiles \ core \ Application \ StimulusPresentation \ MSVCRT.lib (initializers.obj) 1
ykutlu
Post by ykutlu » 12 Feb 2019, 09:40
The output of compile BCI2000.sln file like this
1> ------ Compilation started: Project: BundleStub, Configuration: Release x64 ------
2> ------ Compilation started: Project: VersionCheck, Configuration: Release x64 ------
3> ------ Compilation started: Project: icon-puzzlepiece, Configuration: Release x64 ------
4> ------ Compilation started: Project: icon-wrench, Configuration: Release x64 ------
5> ------ Compilation started: Project: icon-signal-screen, Configuration: Release x64 ------
6> ------ Compilation started: Project: icon-question-mark, Configuration: Release x64 ------
7> ------ Compilation started: Project: icon-prompt, Configuration: Release x64 ------
8> ------ Compilation started: Project: icon-presentation-screen, Configuration: Release x64 ------
2> Building Custom Rule C: /BCI2000src/build/CMakeLists.txt
2> CMake does not need to re-run because C: /BCI2000src/build/CMakeFiles/generate.stamp is up-to-date.
2> CMake Error at C: / Program Files (x86) /cmake-3.8.2-win32-x86/share/cmake-3.8/Modules/FindSubversion.cmake:99 (message):
2> Command "C: / Program Files / TortoiseSVN / bin / svn.exe info C: / BCI2000src"
2> failed with output:
2>
2> svn: E155007: 'C: \ BCI2000src' is not a working copy
2>
2> Call Stack (most recent call first):
2> cmake / MakeVersionInfo.cmake: 9 (Subversion_WC_INFO)
2>
2>
2> - BUILD_DATE set to 2019-02-12Z
1>Stub.obj : error LNK2019: Çözümlenmemiş dış sembol "void * __cdecl operator new[](unsigned __int64)" (??_U@YAPEAX_K@Z), "public: void __cdecl Vector<wchar_t,64>::resize(unsigned __int64)" (?resize@?$Vector@_W$0EA@@@QEAAX_K@Z) işlevinde başvurdu
1>ZipFileSystem.obj : error LNK2001: Çözümlenmemiş dış sembol "void * __cdecl operator new[](unsigned __int64)" (??_U@YAPEAX_K@Z)
1>NtHookFs.obj : error LNK2001: Çözümlenmemiş dış sembol "void * __cdecl operator new[](unsigned __int64)" (??_U@YAPEAX_K@Z)
1>Stub.obj : error LNK2019: Çözümlenmemiş dış sembol "void __cdecl operator delete[](void *)" (??_V@YAXPEAX@Z), "void __cdecl LoadMainExecutable(void)" (?LoadMainExecutable@@YAXXZ) işlevinde başvurdu
1>ZipFileSystem.obj : error LNK2001: Çözümlenmemiş dış sembol "void __cdecl operator delete[](void *)" (??_V@YAXPEAX@Z)
1>NtHookFs.obj : error LNK2001: Çözümlenmemiş dış sembol "void __cdecl operator delete[](void *)" (??_V@YAXPEAX@Z)
1>C:\BCI2000src\build\CMakeFiles\buildutils\AppBundler\BundleStub\Release\BundleStub.exe : fatal error LNK1120: 2 çözümlenmemiş dışlar
1>"BundleStub.vcxproj" projesini oluşturma tamamlandı -- BAŞARISIZ OLDU.
9>------ Derleme başladı: Proje: icon-gui-screen, Yapılandırma: Release x64 ------
2>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" öğesinden 1 koduyla çıkıldı.
2>"VersionCheck.vcxproj" projesini oluşturma tamamlandı -- BAŞARISIZ OLDU.
10>------ Derleme başladı: Proje: icon-film, Yapılandırma: Release x64 ------
11>------ Derleme başladı: Proje: icon-exclamation-mark, Yapılandırma: Release x64 ------
12>------ Derleme başladı: Proje: icon-cogwheel-screen, Yapılandırma: Release x64 ------
13>------ Derleme başladı: Proje: AppBundler (Build\Tools\AppBundler\AppBundler), Yapılandırma: Release x64 ------
14>------ Derleme başladı: Proje: OperatorLib, Yapılandırma: Release x64 ------
15>------ Derleme başladı: Proje: BCI2000Automation64, Yapılandırma: Release x64 ------
16>------ Derleme başladı: Proje: BCI2000PresentationLink64, Yapılandırma: Release x64 ------
17>------ Derleme başladı: Proje: BCI2000PythonBindings, Yapılandırma: Release x64 ------
13>Building Custom Rule C:/BCI2000src/build/buildutils/AppBundler/CMakeLists.txt
13>CMake does not need to re-run because C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/CMakeFiles/generate.stamp is up-to-date.
13>Generating BundleStub.bin
13>'C:\BCI2000src\build\CMakeFiles\buildutils\AppBundler\BundleStub\Release\BundleStub.exe' is not recognized as an internal or external command,
13>operable program or batch file.
13>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" öğesinden 9009 koduyla çıkıldı.
13>"AppBundler.vcxproj" projesini oluşturma tamamlandı -- BAŞARISIZ OLDU.
18>------ Derleme başladı: Proje: BCI2000RemoteLib, Yapılandırma: Release x64 ------
19>------ Derleme başladı: Proje: BCI2000Shell, Yapılandırma: Release x64 ------
20>------ Derleme başladı: Proje: vAmpSource, Yapılandırma: Release x64 ------
21>------ Derleme başladı: Proje: Micromed, Yapılandırma: Release x64 ------
22>------ Derleme başladı: Proje: ARSignalProcessing, Yapılandırma: Release x64 ------
15> C:/BCI2000src/build/CMakeFiles/contrib/ExternalLinks/BCI2000Automation/Release/BCI2000Automation64.lib kitaplığı ve C:/BCI2000src/build/CMakeFiles/contrib/ExternalLinks/BCI2000Automation/Release/BCI2000Automation64.exp nesnesi oluşturuluyor
18> C:/BCI2000src/build/CMakeFiles/core/Operator/BCI2000Remote/Release/BCI2000RemoteLib.lib kitaplığı ve C:/BCI2000src/build/CMakeFiles/core/Operator/BCI2000Remote/Release/BCI2000RemoteLib.exp nesnesi oluşturuluyor
14> C:/BCI2000src/build/CMakeFiles/core/Operator/OperatorLib/Release/OperatorLib.lib kitaplığı ve C:/BCI2000src/build/CMakeFiles/core/Operator/OperatorLib/Release/OperatorLib.exp nesnesi oluşturuluyor
16> C:/BCI2000src/build/CMakeFiles/contrib/ExternalLinks/BCI2000PresentationLink/Release/BCI2000PresentationLink64.lib kitaplığı ve C:/BCI2000src/build/CMakeFiles/contrib/ExternalLinks/BCI2000PresentationLink/Release/BCI2000PresentationLink64.exp nesnesi oluşturuluyor
18>BCI2000RemoteLib.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Operator\BCI2000Remote\Release\BCI2000RemoteLib.dll
16>BCI2000PresentationLink64.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\ExternalLinks\BCI2000PresentationLink\Release\BCI2000PresentationLink64.dll
15>BCI2000Automation64.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\ExternalLinks\BCI2000Automation\Release\BCI2000Automation64.dll
14>OperatorLib.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Operator\OperatorLib\Release\OperatorLib.dll
21>Micromed.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Micromed\Release\Micromed.exe
20>vAmpSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\vAmp\Release\vAmpSource.exe
22>ARSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\AR\Release\ARSignalProcessing.exe
19>BCI2000Shell.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Operator\BCI2000Shell\Release\BCI2000Shell.exe
14> Copy to destination
15> Copy to destination
21> Create application bundle
16> Copy to destination
18> Copy to destination
19> Copy to destination
21>creating bundle:
23>------ Derleme başladı: Proje: AmpServerPro, Yapılandırma: Release x64 ------
20> Create application bundle
24>------ Derleme başladı: Proje: BAlertSource, Yapılandırma: Release x64 ------
22> Create application bundle
20>creating bundle:
25>------ Derleme başladı: Proje: BCI2000CertAnalysis, Yapılandırma: Release x64 ------
26>------ Derleme başladı: Proje: BCI2000CertificationTester, Yapılandırma: Release x64 ------
27>------ Derleme başladı: Proje: BCI2000Command, Yapılandırma: Release x64 ------
22>creating bundle:
21>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
21>operable program or batch file.
21>Error creating bundle.
28>------ Derleme başladı: Proje: BCI2000Export, Yapılandırma: Release x64 ------
23>AmpServerPro.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\AmpServerPro\Release\AmpServerPro.exe
23> Create application bundle
22>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
22>operable program or batch file.
22>Error creating bundle.
29>------ Derleme başladı: Proje: BCI2000FileInfo, Yapılandırma: Release x64 ------
23>creating bundle:
24>BAlertSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\B-Alert\Release\BAlertSource.exe
24> Create application bundle
27>BCI2000Command.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\ExternalLinks\BCI2000Command\Release\BCI2000Command.exe
27> Create application bundle
24>creating bundle:
27>creating bundle:
26>BCI2000CertificationTester.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000Certification\BCI2000CertificationTester\Release\BCI2000CertificationTester.exe
26> Create application bundle
20>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
20>operable program or batch file.
20>Error creating bundle.
27>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
27>operable program or batch file.
27>Error creating bundle.
30>------ Derleme başladı: Proje: BCI2000Launcher, Yapılandırma: Release x64 ------
28>BCI2000Export.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000ExportQt\Release\BCI2000Export.exe
28> Create application bundle
23>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
23>operable program or batch file.
23>Error creating bundle.
31>------ Derleme başladı: Proje: BCI2000MediaPlayer, Yapılandırma: Release x64 ------
32>------ Derleme başladı: Proje: BCI2000Viewer, Yapılandırma: Release x64 ------
28>creating bundle:
24>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
24>operable program or batch file.
24>Error creating bundle.
25>BCI2000CertAnalysis.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000Certification\BCI2000CertificationAnalysis\Release\BCI2000CertAnalysis.exe
25> Create application bundle
33>------ Derleme başladı: Proje: BioRadio, Yapılandırma: Release x64 ------
25>creating bundle:
31>LINK : warning LNK4098: defaultlib 'LIBCMT' diğer kitaplıkların kullanımı ile çakışıyor; /NODEFAULTLIB:library kullanın
28>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
28>operable program or batch file.
32>BCI2000Viewer.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000ViewerQt\Release\BCI2000Viewer.exe
28>Error creating bundle.
34>------ Derleme başladı: Proje: Biosemi2, Yapılandırma: Release x64 ------
32> Create application bundle
33>BioRadio.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\BioRadio\Release\BioRadio.exe
33> Create application bundle
32>creating bundle:
33>creating bundle:
25>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
25>operable program or batch file.
25>Error creating bundle.
35>------ Derleme başladı: Proje: Blackrock, Yapılandırma: Release x64 ------
31>BCI2000MediaPlayer.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000MediaPlayer\Release\BCI2000MediaPlayer.exe
31> Create application bundle
31>creating bundle:
26>creating bundle:
34>Biosemi2.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Biosemi\Release\Biosemi2.exe
34> Create application bundle
34>creating bundle:
33>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
33>operable program or batch file.
33>Error creating bundle.
36>------ Derleme başladı: Proje: BundleTest, Yapılandırma: Release x64 ------
35>Blackrock.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Blackrock\Release\Blackrock.exe
36>BundleTest.vcxproj -> C:\BCI2000src\build\CMakeFiles\buildutils\AppBundler\Test\Release\BundleTest.exe
36>Copy to destination
35> Create application bundle
32>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
32>operable program or batch file.
36>Creating test file "C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/testdata.bin" of size 1048576 ... done.
36>'..\Release\AppBundler.exe' is not recognized as an internal or external command,
36>operable program or batch file.
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: "setlocal
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: "C:\Program Files (x86)\cmake-3.8.2-win32-x86\bin\cmake.exe" -E make_directory C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: if %errorlevel% neq 0 goto :cmEnd
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: "C:\Program Files (x86)\cmake-3.8.2-win32-x86\bin\cmake.exe" -E copy C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test || "C:/Program Files (x86)/cmake-3.8.2-win32-x86/bin/cmake.exe" -E remove C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe && "C:/Program Files (x86)/cmake-3.8.2-win32-x86/bin/cmake.exe" -E touch_nocreate .notexist
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: :cmEnd
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: endlocal & call :cmErrorLevel %errorlevel% & goto :cmDone
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: :cmErrorLevel
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: exit /b %1
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: :cmDone
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: if %errorlevel% neq 0 goto :VCEnd
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: setlocal
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: Release\BundleTest.exe --create 1048576 C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/testdata.bin
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: ..\Release\AppBundler.exe C:/BCI2000src/build/buildutils/BundleTest C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/Release/BundleTest.exe C:/BCI2000src/build/CMakeFiles/buildutils/AppBundler/Test/testdata.bin=test/test.bin
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: ..\..\..\..\buildutils\BundleTest --test 10000 - C:/current.app/test/test.bin
36>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(138,5): error MSB3073: :VCEnd" komutundan 9009 koduyla çıkıldı.
36>"BundleTest.vcxproj" projesini oluşturma tamamlandı -- BAŞARISIZ OLDU.
32>Error creating bundle.
37>------ Derleme başladı: Proje: CoherenceFFTSignalProcessing, Yapılandırma: Release x64 ------
38>------ Derleme başladı: Proje: CoherenceSignalProcessing, Yapılandırma: Release x64 ------
35>creating bundle:
34>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
34>operable program or batch file.
34>Error creating bundle.
39>------ Derleme başladı: Proje: CursorTask, Yapılandırma: Release x64 ------
26>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
26>operable program or batch file.
26>Error creating bundle.
40>------ Derleme başladı: Proje: DASSource, Yapılandırma: Release x64 ------
31>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
31>operable program or batch file.
31>Error creating bundle.
31>"BCI2000MediaPlayer.vcxproj" projesini oluşturma tamamlandı.
41>------ Derleme başladı: Proje: DSISerial, Yapılandırma: Release x64 ------
35>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
35>operable program or batch file.
35>Error creating bundle.
42>------ Derleme başladı: Proje: DummyApplication, Yapılandırma: Release x64 ------
38>CoherenceSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Coherence\Release\CoherenceSignalProcessing.exe
37>CoherenceFFTSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\CoherenceFFT\Release\CoherenceFFTSignalProcessing.exe
38> Create application bundle
37> Create application bundle
38>creating bundle:
37>creating bundle:
40>DASSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\DASSource\Release\DASSource.exe
40> Create application bundle
41>DSISerial.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\DSISerial\Release\DSISerial.exe
40>creating bundle:
41> Create application bundle
41>creating bundle:
42>DummyApplication.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Application\Dummy\Release\DummyApplication.exe
42> Create application bundle
39>CursorTask.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Application\CursorTask\Release\CursorTask.exe
39> Create application bundle
37>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
37>operable program or batch file.
38>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
38>operable program or batch file.
37>Error creating bundle.
38>Error creating bundle.
42>creating bundle:
43>------ Derleme başladı: Proje: DummySignalProcessing, Yapılandırma: Release x64 ------
44>------ Derleme başladı: Proje: Emotiv, Yapılandırma: Release x64 ------
40>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
40>operable program or batch file.
40>Error creating bundle.
45>------ Derleme başladı: Proje: FFTSignalProcessing, Yapılandırma: Release x64 ------
41>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
41>operable program or batch file.
41>Error creating bundle.
29>BCI2000FileInfo.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000FileInfoQt\Release\BCI2000FileInfo.exe
46>------ Derleme başladı: Proje: FIRProcessing, Yapılandırma: Release x64 ------
43>DummySignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\Dummy\Release\DummySignalProcessing.exe
44>Emotiv.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Emotiv\Release\Emotiv.exe
43> Create application bundle
44> Create application bundle
43>creating bundle:
44>creating bundle:
45>FFTSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\FFT\Release\FFTSignalProcessing.exe
45> Create application bundle
39>creating bundle:
45>creating bundle:
46>FIRProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\FIR\Release\FIRProcessing.exe
46> Create application bundle
42>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
42>operable program or batch file.
42>Error creating bundle.
47>------ Derleme başladı: Proje: FeedbackDemo, Yapılandırma: Release x64 ------
46>creating bundle:
43>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
43>operable program or batch file.
43>Error creating bundle.
44>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
44>operable program or batch file.
44>Error creating bundle.
48>------ Derleme başladı: Proje: FilePlayback, Yapılandırma: Release x64 ------
29> Create application bundle
45>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
45>operable program or batch file.
45>Error creating bundle.
49>------ Derleme başladı: Proje: Grapevine, Yapılandırma: Release x64 ------
29>creating bundle:
50>------ Derleme başladı: Proje: HilbertSignalProcessing, Yapılandırma: Release x64 ------
46>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
46>operable program or batch file.
46>Error creating bundle.
51>------ Derleme başladı: Proje: LSLSource, Yapılandırma: Release x64 ------
47>FeedbackDemo.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Application\FeedbackDemo\Release\FeedbackDemo.exe
47> Create application bundle
47>creating bundle:
48>FilePlayback.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\FilePlayback\Release\FilePlayback.exe
48> Create application bundle
49>Grapevine.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Ripple\Release\Grapevine.exe
48>creating bundle:
49> Create application bundle
39>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
39>operable program or batch file.
39>Error creating bundle.
52>------ Derleme başladı: Proje: LiveAmpSource, Yapılandırma: Release x64 ------
29>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
29>operable program or batch file.
29>Error creating bundle.
49>creating bundle:
50>HilbertSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\HilbertSignalProcessing\Release\HilbertSignalProcessing.exe
50> Create application bundle
53>------ Derleme başladı: Proje: MatlabSignalProcessing, Yapılandırma: Release x64 ------
50>creating bundle:
51>LSLSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\LSLSource\Release\LSLSource.exe
51> Create application bundle
51>creating bundle:
47>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
48>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
48>operable program or batch file.
48>Error creating bundle.
47>operable program or batch file.
47>Error creating bundle.
54>------ Derleme başladı: Proje: MessageBox, Yapılandırma: Release x64 ------
49>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
49>operable program or batch file.
49>Error creating bundle.
55>------ Derleme başladı: Proje: gUSBampSource, Yapılandırma: Release x64 ------
50>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
50>operable program or batch file.
50>Error creating bundle.
56>------ Derleme başladı: Proje: ModularEEG, Yapılandırma: Release x64 ------
57>------ Derleme başladı: Proje: NIDAQ_mx_Source, Yapılandırma: Release x64 ------
52>LiveAmpSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\LiveAmp\Release\LiveAmpSource.exe
52> Create application bundle
52>creating bundle:
53>MatlabSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\Matlab\Release\MatlabSignalProcessing.exe
53> Create application bundle
30>BCI2000Launcher.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\BCI2000LauncherQt\Release\BCI2000Launcher.exe
51>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
51>operable program or batch file.
51>Error creating bundle.
58>------ Derleme başladı: Proje: NeuroSky, Yapılandırma: Release x64 ------
30> Create application bundle
53>creating bundle:
30>creating bundle:
55>gUSBampSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.USBamp\Release\gUSBampSource.exe
55> Create application bundle
52>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
52>operable program or batch file.
55>creating bundle:
52>Error creating bundle.
56>ModularEEG.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\ModularEEG\Release\ModularEEG.exe
59>------ Derleme başladı: Proje: NeuroscanAccess, Yapılandırma: Release x64 ------
56> Create application bundle
57>NIDAQ_mx_Source.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\NIDAQ-MX\Release\NIDAQ_mx_Source.exe
57> Create application bundle
56>creating bundle:
57>creating bundle:
53>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
53>operable program or batch file.
53>Error creating bundle.
58>NeuroSky.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\NeuroSky\Release\NeuroSky.exe
60>------ Derleme başladı: Proje: NeuroscanClient, Yapılandırma: Release x64 ------
58> Create application bundle
58>creating bundle:
55>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
59>NeuroscanAccess.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\NeuroscanAccessSDK\Release\NeuroscanAccess.exe
55>operable program or batch file.
55>Error creating bundle.
59> Create application bundle
56>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
56>operable program or batch file.
56>Error creating bundle.
57>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
57>operable program or batch file.
57>Error creating bundle.
61>------ Derleme başladı: Proje: OpenBCISource, Yapılandırma: Release x64 ------
30>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
30>operable program or batch file.
30>Error creating bundle.
58>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
58>operable program or batch file.
58>Error creating bundle.
62>------ Derleme başladı: Proje: Operator (Core\Operator\Operator), Yapılandırma: Release x64 ------
63>------ Derleme başladı: Proje: P300Classifier, Yapılandırma: Release x64 ------
64>------ Derleme başladı: Proje: P3SignalProcessing, Yapılandırma: Release x64 ------
54>MessageBox.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Operator\MessageBox\Release\MessageBox.exe
54> Copy to destination
65>------ Derleme başladı: Proje: P3Speller, Yapılandırma: Release x64 ------
66>------ Derleme başladı: Proje: PeakDetectSignalProcessing, Yapılandırma: Release x64 ------
59>creating bundle:
59>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
59>operable program or batch file.
59>Error creating bundle.
60>NeuroscanClient.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\Neuroscan\Release\NeuroscanClient.exe
60> Create application bundle
60>creating bundle:
67>------ Derleme başladı: Proje: PyffApplication, Yapılandırma: Release x64 ------
61>OpenBCISource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\OpenBCISource\Release\OpenBCISource.exe
61> Create application bundle
60>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
60>operable program or batch file.
60>Error creating bundle.
68>------ Derleme başladı: Proje: PythonApplication, Yapılandırma: Release x64 ------
65>MSVCRT.lib(initializers.obj) : warning LNK4098: defaultlib 'libcmt.lib' diğer kitaplıkların kullanımı ile çakışıyor; /NODEFAULTLIB:library kullanın
61>creating bundle:
64>P3SignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\P3\Release\P3SignalProcessing.exe
64> Create application bundle
63>P300Classifier.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\P300Classifier\Release\P300Classifier.exe
63> Create application bundle
64>creating bundle:
66>PeakDetectSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\PeakDetector\Release\PeakDetectSignalProcessing.exe
67>PyffApplication.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\ExternalLinks\PyffApplication\Release\PyffApplication.exe
63>creating bundle:
66> Create application bundle
67> Create application bundle
66>creating bundle:
67>creating bundle:
65>P3Speller.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Application\P3Speller\Release\P3Speller.exe
65> Create application bundle
61>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
61>operable program or batch file.
61>Error creating bundle.
68>PythonApplication.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\BCPy2000\foundation\Application\Release\PythonApplication.exe
69>------ Derleme başladı: Proje: PythonSignalProcessing, Yapılandırma: Release x64 ------
68> Create application bundle
64>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
64>operable program or batch file.
64>Error creating bundle.
70>------ Derleme başladı: Proje: PythonSource, Yapılandırma: Release x64 ------
68>creating bundle:
66>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
66>operable program or batch file.
66>Error creating bundle.
71>------ Derleme başladı: Proje: RDAClient, Yapılandırma: Release x64 ------
69>PythonSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\BCPy2000\foundation\SignalProcessing\Release\PythonSignalProcessing.exe
67>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
67>operable program or batch file.
69> Create application bundle
67>Error creating bundle.
72>------ Derleme başladı: Proje: RDAgetparams, Yapılandırma: Release x64 ------
63>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
63>operable program or batch file.
63>Error creating bundle.
73>------ Derleme başladı: Proje: SWSignalProcessing, Yapılandırma: Release x64 ------
69>creating bundle:
70>PythonSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\BCPy2000\foundation\SignalSource\Release\PythonSource.exe
70> Create application bundle
70>creating bundle:
71>RDAClient.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\RDAClient\Release\RDAClient.exe
71> Create application bundle
71>creating bundle:
68>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
68>operable program or batch file.
68>Error creating bundle.
74>------ Derleme başladı: Proje: SignalGenerator, Yapılandırma: Release x64 ------
65>creating bundle:
72>RDAgetparams.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\RDAClient\getparams\Release\RDAgetparams.exe
72> Create application bundle
69>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
69>operable program or batch file.
69>Error creating bundle.
72>creating bundle:
70>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
70>operable program or batch file.
70>Error creating bundle.
75>------ Derleme başladı: Proje: SoundcardSource, Yapılandırma: Release x64 ------
76>------ Derleme başladı: Proje: SpectralSignalProcessing, Yapılandırma: Release x64 ------
72>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
72>operable program or batch file.
72>Error creating bundle.
71>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
71>operable program or batch file.
71>Error creating bundle.
73>SWSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\SW\Release\SWSignalProcessing.exe
73> Create application bundle
77>------ Derleme başladı: Proje: StatisticsSignalProcessing1, Yapılandırma: Release x64 ------
78>------ Derleme başladı: Proje: StatisticsSignalProcessing2, Yapılandırma: Release x64 ------
73>creating bundle:
74>SignalGenerator.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\SignalGenerator\Release\SignalGenerator.exe
74> Create application bundle
62>Operator.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Operator\OperatorQt\Release\Operator.exe
75>SoundcardSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\SoundcardSource\Release\SoundcardSource.exe
75> Create application bundle
76>SpectralSignalProcessing.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalProcessing\Spectral\Release\SpectralSignalProcessing.exe
73>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
73>operable program or batch file.
76> Create application bundle
74>creating bundle:
73>Error creating bundle.
75>creating bundle:
79>------ Derleme başladı: Proje: StatisticsSignalProcessing4, Yapılandırma: Release x64 ------
76>creating bundle:
77>StatisticsSignalProcessing1.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Statistics\Release\StatisticsSignalProcessing1.exe
78>StatisticsSignalProcessing2.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Statistics\Release\StatisticsSignalProcessing2.exe
77> Create application bundle
78> Create application bundle
77>creating bundle:
78>creating bundle:
65>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
65>operable program or batch file.
65>Error creating bundle.
78>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
78>The system cannot find the file C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Statistics\Release\.depends.
78>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
78>operable program or batch file.
78>Error creating bundle.
65>"P3Speller.vcxproj" projesini oluşturma tamamlandı.
80>------ Derleme başladı: Proje: StimulusPresentation, Yapılandırma: Release x64 ------
81>------ Derleme başladı: Proje: TDTSampleRate, Yapılandırma: Release x64 ------
74>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
74>operable program or batch file.
74>Error creating bundle.
76>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
76>operable program or batch file.
76>Error creating bundle.
75>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
75>operable program or batch file.
75>Error creating bundle.
82>------ Derleme başladı: Proje: TMSi, Yapılandırma: Release x64 ------
83>------ Derleme başladı: Proje: TuckerDavis, Yapılandırma: Release x64 ------
79>StatisticsSignalProcessing4.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Statistics\Release\StatisticsSignalProcessing4.exe
79> Create application bundle
79>creating bundle:
79>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
79>The system cannot find the file C:\BCI2000src\build\CMakeFiles\contrib\SignalProcessing\Statistics\Release\.depends.
79>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
79>operable program or batch file.
79>Error creating bundle.
84>------ Derleme başladı: Proje: actiCHampSource, Yapılandırma: Release x64 ------
77>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
77>operable program or batch file.
77>Error creating bundle.
85>------ Derleme başladı: Proje: bci_dat2stream, Yapılandırma: Release x64 ------
86>------ Derleme başladı: Proje: bci_decimate, Yapılandırma: Release x64 ------
62> Create application bundle
62>creating bundle:
81>TDTSampleRate.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\TuckerDavis\TDTSampleRate\Release\TDTSampleRate.exe
81>Create application bundle
81>creating bundle:
80>MSVCRT.lib(initializers.obj) : warning LNK4098: defaultlib 'libcmt.lib' diğer kitaplıkların kullanımı ile çakışıyor; /NODEFAULTLIB:library kullanın
80>StimulusPresentation.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Application\StimulusPresentation\Release\StimulusPresentation.exe
80> Create application bundle
83>TuckerDavis.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\TuckerDavis\Release\TuckerDavis.exe
82>TMSi.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\TMSi\Release\TMSi.exe
82> Create application bundle
83> Create application bundle
82>creating bundle:
83>creating bundle:
84>actiCHampSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\contrib\SignalSource\actiCHamp\Release\actiCHampSource.exe
81>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
84> Create application bundle
81>operable program or batch file.
81>Error creating bundle.
87>------ Derleme başladı: Proje: bci_prm2stream, Yapılandırma: Release x64 ------
85>bci_dat2stream.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_dat2stream.exe
85> Create application bundle
84>creating bundle:
62>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
62>operable program or batch file.
86>bci_decimate.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_decimate.exe
62>Error creating bundle.
86> Create application bundle
88>------ Derleme başladı: Proje: bci_stream2asc, Yapılandırma: Release x64 ------
85>creating bundle:
86>creating bundle:
86>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
86>The system cannot find the file C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\.depends.
86>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
86>operable program or batch file.
86>Error creating bundle.
89>------ Derleme başladı: Proje: bci_stream2mat, Yapılandırma: Release x64 ------
85>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
85>operable program or batch file.
85>Error creating bundle.
90>------ Derleme başladı: Proje: bci_stream2prm, Yapılandırma: Release x64 ------
82>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
82>operable program or batch file.
82>Error creating bundle.
91>------ Derleme başladı: Proje: bci_stream2table, Yapılandırma: Release x64 ------
83>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
83>operable program or batch file.
83>Error creating bundle.
92>------ Derleme başladı: Proje: gHIampSource, Yapılandırma: Release x64 ------
87>bci_prm2stream.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_prm2stream.exe
87> Create application bundle
84>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
84>operable program or batch file.
84>Error creating bundle.
93>------ Derleme başladı: Proje: gMOBIlab, Yapılandırma: Release x64 ------
87>creating bundle:
88>bci_stream2asc.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_stream2asc.exe
88> Create application bundle
89>bci_stream2mat.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_stream2mat.exe
89> Create application bundle
88>creating bundle:
88>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
88>The system cannot find the file C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\.depends.
88>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
88>operable program or batch file.
88>Error creating bundle.
89>creating bundle:
89>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
89>The system cannot find the file C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\.depends.
89>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
89>operable program or batch file.
89>Error creating bundle.
94>------ Derleme başladı: Proje: gMOBIlabPlus, Yapılandırma: Release x64 ------
87>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
87>operable program or batch file.
87>Error creating bundle.
90>bci_stream2prm.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_stream2prm.exe
90> Create application bundle
95>------ Derleme başladı: Proje: gNautilusSource, Yapılandırma: Release x64 ------
90>creating bundle:
91>bci_stream2table.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\bci_stream2table.exe
91> Create application bundle
96>------ Derleme başladı: Proje: gUSBampgetinfo, Yapılandırma: Release x64 ------
92>gHIampSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.HIampSource\Release\gHIampSource.exe
92> Create application bundle
91>creating bundle:
91>Dosya başka bir işlem tarafından kullanıldığından bu işlem dosyaya erişemiyor.
91>The system cannot find the file C:\BCI2000src\build\CMakeFiles\core\Tools\cmdline\Release\.depends.
91>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
91>operable program or batch file.
91>Error creating bundle.
97>------ Derleme başladı: Proje: gUnicornADC, Yapılandırma: Release x64 ------
92>creating bundle:
90>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
90>operable program or batch file.
90>Error creating bundle.
93>gMOBIlab.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.MOBIlab\Release\gMOBIlab.exe
93> Create application bundle
93>creating bundle:
80>creating bundle:
96>gUSBampgetinfo.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.USBamp\getinfo\Release\gUSBampgetinfo.exe
96> Create application bundle
92>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
92>operable program or batch file.
92>Error creating bundle.
96>creating bundle:
94>gMOBIlabPlus.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.MOBIlabPlus\Release\gMOBIlabPlus.exe
95>gNautilusSource.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.NautilusSource\Release\gNautilusSource.exe
94> Create application bundle
95> Create application bundle
94>creating bundle:
95>creating bundle:
93>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
93>operable program or batch file.
97>gUnicornADC.vcxproj -> C:\BCI2000src\build\CMakeFiles\core\SignalSource\g.Unicorn\Release\gUnicornADC.exe
93>Error creating bundle.
97> Create application bundle
96>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
96>operable program or batch file.
96>Error creating bundle.
97>creating bundle:
94>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
94>operable program or batch file.
94>Error creating bundle.
95>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
95>operable program or batch file.
97>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
97>operable program or batch file.
95>Error creating bundle.
97>Error creating bundle.
80>'"C:\BCI2000src\build\buildutils\AppBundler"' is not recognized as an internal or external command,
80>operable program or batch file.
80>Error creating bundle.
80> The project "StimulusPresentation.vcxproj" has been completed.
98> ------ Skipped Compilation Process: Project: ALL_BUILD, Configuration: Release x64 ------
98> No project selected to create this solution configuration
========== Create: 93 successful, 4 failed, 23 updated, 1 skipped ==========
Post by mellinger » 13 Feb 2019, 09:27
I still don't understand why you are getting these errors, but as a workaround you might disable "USE_APPLICATION_BUNDLES" in CMake.
Let me know whether this fixes the problem for you.
ykutlu
Post by ykutlu » 19 Mar 2019, 06:40
ı did everything but it didn't work.I couldn't find where is the problem can you help me ?
jordanpowell
Post by jordanpowell » 03 Apr 2019, 16:23
I had the same issue. I resolved it by doing the following:
1st: Do a new SVN Pull using the following link http://www.bci2000.org/svn/trunk <---there are two links on wiki, use this one not the other
2nd: Once you link Qt and configure the files go to USE and disable USE_APPLICATION_BUNDLES.
3rd: Go to Build > Configuration Manager > Deselect BCI2000 Viewer in both Release and Debug Mode.
The BCI2000 Viewer causes one of your errors, You can deselect it so VS does not attempt to build it. Those three steps should eliminate most of the errors you are receiving.
