My EEG system can stream its data to another PC via a UDP port. Is there a tutorial/walkthrough that will show me how to use BCI2000 to access this data via the UDP port and then put the EEG data through a processing pipeline such as accessing the mu rhythm from the UDP streamed raw EEG?
Thank you,
Tom
Is there a good walk through to access EEG data through UDP
Users browsing this forum: Ahrefs [Bot] and 1 guest
