Start and suspend from batch file
lavincent
Post by lavincent » 26 Sep 2016, 13:59
Hi all,
sorry if in the wrong forum section, but i don't know where this post could be more appropriate.
Anyone knows why this error: ...path\batch_file.bat, line 22: Wait aborted
when i try to execute this:
Change directory $BCI2000LAUNCHDIR
Show window; Set title ${Extract file base $0}
Reset system
Startup system localhost
Start executable SignalGenerator --local
Start executable DummySignalProcessing --local
Start executable DummyApplication --local
Wait for Connected
Start executable MyApp --local
Load parameterfile "../parms/testParams.prm"
SET CONFIG
START
WAIT FOR Suspended 5
Thank you
Re: Start and suspend from batch file
Post by pbrunner » 26 Sep 2016, 15:00
Lavincent,
I could reproduce the issue with the "WAIT FOR" command in the operator script. I will let you know once this issue is resolved.
Unrelated to this, I have noticed that you are starting two application modules. Please note that only one will connect, specifically the fist one in your list. I would like to suggest, that you replace the DummyApplication in your script with your MyApp.
lavincent
Post by lavincent » 27 Sep 2016, 05:53
OK thank you Peter,
let me know if you need more information.
Anyway thanks again for your suggestion, I've created an UDP socket in MyApp to receive the datagrams.
I also asked help here:
http://www.bci2000.org/bbs/viewtopic.php?f=5&t=3355
Regards, LaV
Post by pbrunner » 28 Sep 2016, 13:41
Lavincent,
the bug is now fixed in SVN revision 5553. Please update your source code to the trunk (currently revision 5555) and re-compile. Thanks again for reporting the issue.
lavincent
Post by lavincent » 29 Sep 2016, 08:05
Welcome.
Thanks for support. Regards
