Only receiving "Running 1"
lavincent
Post by lavincent » 30 May 2016, 05:45
Hi all,
I'm continuing my experiment with BCI2000. I've design my own application and now I'm trying to connect bci to it.
I've created an UDP socket with port 5000. In ConnectorOutputAddress i wrote "localhost:5000" (bci and app are on the same computer).
So, the connections starts correctly but the only info I can receive is "Running 1" (or "Running 0" when suspend). I'm programming in C#.
I'm trying to receive signals from CursorTask_SignalGenerator file batch.
Ideas to receive all signal informations?
Thank you.
Re: Only receiving "Running 1"
Post by pbrunner » 01 Jun 2016, 16:51
Lavncent,
you should be receiving more state. It could be that your C# implementation is faulty. Can you please try the AppConnectorExample or the readudp.m MATLAB script as detailed in the tutorial:
lavincent
Post by lavincent » 02 Jun 2016, 12:42
Hi Peter,
thank you for your continued support.
Yes, my code was somehow wrong.
If someone can find it helpful, I solved the problem adding the function .Recive() in more than one line. In this way, the socket is able to receive all UDP datagram.
Ty again,
LaV
