FieldTrip with Bci2000
lucamossa
Post by lucamossa » 05 May 2014, 06:50
Hi to everyone,
I'm currently trying to use FieldTripBuffer (in matlab) as the Signal Processing module for a mu rhythm application. I have no problems to read the raw signal and states but I have trouble to find a way to sent the processing result back to Bci.
First, it is possible do this, i.e. resend the processing data back to the application module of Bci?
I must use the function ft_write_data?
some ideas?
thanks
lucamossa
Re: FieldTrip with Bci2000
Post by lucamossa » 14 May 2014, 06:21
The solution is to use ft_write_event. From the fieldtrip perspective it is an event, whereas from the BCI2000 perspective it is a signal vector.
Regards.
