<SAVE> and <RETR> speller command not working
assg
Post by assg » 24 Feb 2014, 14:17
I'm working on a bci2000 speller experiment, however in order to retrieve text and load text I need the <SAVE> and <RETR> command to be operational. When I call the <SAVE> command, it records it in the activity log however it doesn't generate the new file nor erase the text in the text window. The <RETR> command doesn't work as it is supposed to either.
As defined by the bci2000 wiki:
When the <SAVE> command is selected, the text in the text window will get written to a file and be erased from the window. The file name will be auto generated with the date and time stamp. The directory to which the file gets sent is configured in the TextWindowFilePath parameter. The <RETR> (retrieve) function reads the latest file that was saved by the user and recalls the text into the text window.
Can someone please help me with this issue?
Thanks in advance!
