run the bci 2000
aminhm
run the bci 2000
Post by aminhm » 23 Nov 2013, 06:14
Dear BCI2000 specialists
i face to this problem.
I installed the bci2000 and run the BCI2000 launcher, signal source (g.HIamp), signal processing (spectral signal processing), application (courser task) and parameter files (courser task signal generator) were selected then lunched.
BCI2000 operator page appeared but all the bottoms (config config set and start) are not active !
What is the problem? And how can I solve it
Thanks all
Re: run the bci 2000
Post by boulay » 23 Nov 2013, 18:39
Can you please try running one of the batch files found in BCI2000\batch?
Try running one named something similar to "CursorTask_SignalGenerator.bat".
Let us know if that works better for you.
Post by mellinger » 25 Nov 2013, 08:24
BCI2000 comes with a GettingStarted document in its root directory.
Please make sure that you read and follow that short introduction into how to start up and use BCI2000.
