biosemi2
haozeyin61
biosemi2
Post by haozeyin61 » 13 Oct 2017, 22:20
I set the biosemi as the amplifier.Everything works well when running the BCI2000Laucher.exe and selecting the signal source,signal processing and application.However,an error occured when i only launch the biosemi2,it says "could not connect to operator module". How can i fix this problem? Any help would be highly appreciate.
Re: biosemi2
Post by mellinger » 23 Oct 2018, 10:34
You cannot run biosemi2.exe on its own, only in conjunction with the operator module.
