Information's sending
Paico
Post by Paico » 05 Sep 2016, 12:31
Hi I have sent messages through UDP but, I send parameters that are superfluous information,
making between readings of channel values have values of 0.
Is there any way to reduce the message sent to only send the value of the channels?
Thanks!
Re: Information's sending
Post by pbrunner » 08 Sep 2016, 10:26
Paico,
you can use the "ADD WATCH" command in the AppConnector scripting to specify the variable that are transmitted:
