the question about connecting the bci2000 to the ardunio
summersun
Re: the question about connecting the bci2000 to the ardunio
Post by summersun » 09 Oct 2015, 04:16
Dear pbrunner
when I run the BCI2000 launcher.exe .it said QtGuid4.dll is missing and I have add the Qt bin folder to the system path and it still show the same problem . and when I switch my bci2000 release branch to the trunk , the SVN show "Error : No write-lock in 'C:\bci2000\bci complete\new folder\BCI2000\prog' .And then SVN said Switch Failed.
can you help me fix this problem ? thank you
Post by pbrunner » 09 Oct 2015, 10:06
Summersun,
please use the SVN trunk [1], as this will be come the release shortly. This should fix your issues.
Post by pbrunner » 01 Mar 2016, 16:01
Please use the instructions posted in the BCI2000 v3.6 beta testing thread to download and compile the source code from the
http://www.bci2000.org/svn/trunk repository.
