2D task
simona
2D task
Post by simona » 26 Jul 2005, 10:23
Hallo,
I would like to try 2D task.
I would like to know if I set well some parametrs because my best subject is well trained in both vertical and horizontal movement, but he couldn't perform 2D task very well. I don't know if the problem is in the training or if there is a mistake in the parameters I use in 2Dbox module.
I was able to get the cursor to move at the desidered speed by setting the the sample block size and the parameters XPixelsPerSecond and YpixelsPerSecond. I also set XTrendControl=2 and YTrendControl=2 to make the cursor move in both X and y directions. The value in the seventh line of the matrix cursor pos is 3.
I also set:
-outcome direction=1
-4raw in the matrix weight control: Xadapt, Yadapt,AdaptCOde, Result code.
-weight use=1
What's wrong?!?
I'm looking forward your answer!!
Simona
D2Box ...
Post by gschalk » 03 Aug 2005, 10:06
Simona,
I suggest that you load the 2D fragments that are in the parms/fragments directory. They have all relevant parameters set properly. Also, you can find additional information in the BCI2000 User Manual.
