Irregular Timing program
Elizabeth
Post by Elizabeth » 25 Jan 2005, 11:53
I downloaded the Irregular Timing program as suggested on the BCI website to test our data translation board (http://www.bciresearch.org/html/irregular_timing.html). I open the program, change the board name from 'BCI_IN' to 'dt3003' and press Start, but nothing happens (no signal appears in the window at the bottom of the program). The BCI2000 program can be running or not at the same time, but the Irregular Timing program doesn't do anything either way. I also tried putting in different values for sampling rate and block size, which doesn't seem to matter either. Does anyone have a suggestion for making it work?
Elizabeth Felton
UW-Madison
Re: Irregular Timing program
Post by gschalk » 25 Jan 2005, 19:38
Elisabeth,
I assume you named your board 'dt3003' in the DT Open Layers Control Panel? Please let me know. BCI2000 should definitely not run at the same time.
Let me know.
Elizabeth
Post by Elizabeth » 26 Jan 2005, 17:07
Yes, the board is named dt3003 in the control panel.
Elizabeth
Fixed DT3000Test
Post by gschalk » 27 Jan 2005, 09:09
Elisabeth,
The issues with the test program are now fixed and it should work again. Please download it from the Downloads Section and let me know if it worked. Thanks.
Elizabeth
Re: Fixed DT3000Test
Post by Elizabeth » 27 Jan 2005, 10:51
Yes, the new version I downloaded today works just fine.
Elizabeth
Users browsing this forum: No registered users and 6 guests
