Problem running cursorTask example
fragosoa
Post by fragosoa » 13 Jul 2017, 12:22
Hi, I've been working with bci2000 for a little time (less than 2 months), and I'm currently trying to run cursorTask using a gap with 16 electrodes.
I've done the training session (and specifically every step in the mu tutorial https://www.bci2000.org/mediawiki/index.php/User_Tutorial:Mu_Rhythm_BCI_Tutorial).
I've implemented the 1D cursor task movement, using laplacian spacial filter, FFT in spectral estimation and spectral amplitude in output type. I've found the weight estimator for the linear classifier using the load_bcidat.m file. So, the problem is the coursor doesn't move as good as I want. I've got a consistent movement but it isn't perfect. Any advices?
Thank you for advance for your help.
Users browsing this forum: No registered users and 6 guests
