error MSB6006: "cmd.exe" exited with code -1
Posted: 06 Oct 2016, 06:08
by joyce_jin
Hi Peter,
Now, I have many cmd.exe exited errors like below:
Error 15 error MSB6006: "cmd.exe" exited with code -1. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets 172 5 bci_stream2asc
Error 17 error MSB6006: "cmd.exe" exited with code 78. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets 172 5 BAlertSource
Error 16 error MSB6006: "cmd.exe" exited with code 1. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Microsoft.CppCommon.targets 172 5 AmpServerPro
I saw a known issue like this because of the Anti virus program, but I'm quite sure no any such program like this.
Could you help me? Thanks! Troubled you so much recently, hope you not bothered.
Joyce Jin,
Best Regards.
Re: error MSB6006: "cmd.exe" exited with code -1
Posted: 06 Oct 2016, 10:52
by pbrunner
Joyce_lin,
to further isolate the issue, can you please verify the version of Visual Studio 2012 and CMake on your machine?
Specifically, can you please start Visual Studio and click at at "About Microsoft Visual Studio" in the "Help" menu. Then please report back the Version string which should be something like "Version 11.0...... Update 4". It is important that you have the "Update 4" installed.
Next please go to the cmd shell and type "cmake -version" and report back the version string.
Posted: 07 Oct 2016, 01:20
by joyce_jin
HI peter,
Visual Studio: Version 11.0.61030.00 Update 4
and the cmake version is 3.3.2
Best regard,
Joyce Jin.
Posted: 07 Oct 2016, 10:33
by pbrunner
Joyce,
ok, it seems like you have the required version of Visual Studio and CMake installed.
The next thing I would try is to check that you have enough free storage on your hard drive.
Further, I would suggest that you check out a fresh stack from the BCI2000 SVN trunk and try to compile that.
If this fails, I can offer to take a look remotely through TeamViewer.
Posted: 07 Oct 2016, 11:40
by joyce_jin
Hi Peter,
I'm y sorry to say maybe I need a remote teamviewer. You can contact me when you're convenient. Thanks.
Joyce Jin
